Weatherpack?
AgentX
Over 1,000 Posts
Anyone using Weatherpack connectors? Thoughts? Worth the cost?
Especially since I plan on keeping connections tucked away out of sight, and my bike's not strictly "vintage" anymore, I can't think of a good reason (other than expense) not to switch from brass bullet/blade connectors and nylon blocks.
I figure my bike gives me enough problems, and any way to seal out gremlins is a good thing.
Holy hell. Just been pricing it. It's not cheap...plus the $90 ratcheting crimper...! If I was building harnesses all day it'd be worth it within a few hours, but for me? I dunno. Maybe I should just go crazy with high-quality adhesive heat shrink over standard connections.
I do know that using the $30 non-ratcheting crimper which requires multiple crimps (seal and wire) for each connection looks like a poor way to do it.
Edit: Also looks like there's no option for 2- or 3-into-one connections, which sucks. Guess I'll stick with the way I've been doing things...which is good now that I finally know how to do it right.
I used to work in a restoration shop (old Toyota Land Cruisers) and have built a few complete harnesses. It is worth it to me to build a good harness that won't have voltage leaks. I only want to do it once.
I agree, which is why I was looking into weatherpack. But on a simple bike I don't know if it's justifying the cost; there are other ways to seal the connections. Just less convenient when you have to open it back up.
I also have another build bike lined up behind the current one. And I have a chassis that I want to rat rod. So the I know that I will be using it all again.
Definitely sounds worth it for you...if I had the cash I'd do it, too, but I've been splurging elsewhere on this project so I'll have to leave this one out.
The system is definitely a cool, well-thought-out one.
Am I right, though, in that it doesn't have 2- or 3-into-one connectors?? Can't find them anywhere.
Have you checked out eastern Beaver for connectors? There are other suppliers, but they are reasonably priced
I've used similar weatherseal ones before and find them to be RPA for fault fining as you can get a meter probe into the connector.
Hmmm, the more I think about the prospect of old fashioned block connectors out behind my headlamp in bad weather, the more this actually begins to make sense again.
I think I'm going to go for it. $100 for the crimp tool might pay for itself pretty quickly compared to an electrical issue down the line.
