THansenite
I’ve been helping a buddy get his ‘81 CB750K up and running. The bike now runs well, but we are running into some electrical gremlins that have me scratching my head. Below is a list of what currently works vs. what doesn’t work:
Headlamp (high beam works, low beam doesn’t)
Brake light (low brightness doesn’t work, but lights up when brakes depressed)
Blinkers (come on after a second delay, but don’t flash)
I verified the filaments in the headlight and brake light are both good.
Likely related, there is a hot start issue. The bike will fire up when cold no problem. After riding for a while, if we turn it off and try starting again, it sounds like a dead battery. We can hear the starter solenoid click and the engine try to turn over once, then after that, it acts like the battery is dead with the solenoid clicking, but nothing else happening. If we let it sit for an hour or so, it will fire back up. The battery was at 11.5-12.3 volts the whole time while trying (though it would drop to 9.x when we hit the starter). The solenoid is a new unit.
When using my cheap multimeter, It said I was only getting about .1 volt to the main brake light power (on during normal riding) and I saw that voltage a few other places. My meter was acting a little wonky while testing, so it might have just been registering electrical noise or something.
After looking at the wiring diagram, I saw all of the power for lights and accessories goes through the starter, then out through the smaller diameter wire to the main harness. I was getting full power to the main power wire up to the point it goes into the harness so the only thing I can think of is a short further along in the harness.
If anyone has any other ideas, Please let me know.
