weird headlight issue.. '81 CB750C
rallyimp05
hey,
So my BC750 headlight (low and high, as well as highbeam indicator light) stopped working the other day. I replaced the bulb, checked the fuze, and tested voltage. I was getting 0 off the plug and the switch. all other lights and accessories work. the weird thing is that when I was testing at the wires coming off the top of the switch and accidentally hit the horn, the voltage jumped to around 5v... any ideas why this might be? there looks to be some pinching of the wire bundle that runs to the headlamp housing from the handlebar switches, I am going to investigate that more tomorrow. Just hoping for Ideas of where to start. electrical isn't really my strong point.
I'll have to dig out manual for wiring diagram, been almost 30yrs since I worked on them
Sounds like one of the solder joints may have failed or maybe just the switch wiring is damaged inside insulation?
So this is going to sound stupid, but it's fixed. I assumed that the fuse diagram under the fuse cover showed the locations of the fuses directly under the label. It's reversed, so when you pull it off and flip it over it corresponds with the fuse location. In short I replaced the wrong fuse. Derp... It was a good excuse to upgrade the headlamp and fix a couple other things though!
LOL, glad it was real simple, trying to fix electrical problems by e-mail can be 'quite difficult' ;D
