Weird idle
my-79-750-k
Therapy is expensive. Riding is cheap. You decide.
So when I'm sitting there cold, the bike just doesn't want to stay running (at normal low idle). I'm thinking that's just do to ill-adjusted idle setting. However, if I'm haulin' down the road, and have to let off all of a sudden, then the engine takes 10-20 seconds to come down to idle (with clutch pulled in and no throttle). Any ideas what could be causing this? Maybe some kind of idle return spring of some sort?
Sync the carbs!
1. Tappets/valve adjustment
2. Timing check/adjustment
3. Sync carbs
I would 1-Lube or replace the throttle cable and check the routeing to make sure there are no kinks in the cable. 2-check the fuel mixture screws to make sure they are to spec. 3-check the revs at idle to make sure that is as specified and then sync the carbs. 4- and maybe this should be #1, remove and clean the carbs paying particular attention to the choke/enricher curcuits or jets.
Terry
J'ville,Fl.
Terry
J'ville,Fl.
Yeah, so basically everything you just said about working on the carbs is in the plans, but hasn't been started yet. And the tach isn't working right now, so checking the rpm's at speed and idle are out for the moment until the replacement unit gets here. Anyone know a good site that shows a breakdown and reassembly of the carbs and intakes? And maybe one that gives all the idle and A/F ratio info?
Tim said:
Sync the carbs!
3. Sync carbs
How hard is it really to sync 4 carbs together? I've been told it's like trying to tickle a hungry lion. And, call me a newb, but how do you adjust your valves without completely tearing the engine apart, which I want to avoid.
Your going to have to spend some cash.
Even though many people can do the work themselves, your really not ready to do that and can cause more problems than you solve.
You will need sync gauges to sync carbs, about $170.00 on eBay or various other places
You shouldn't have to pay more than 3.5 hrs labour at dealers to get everything put right ( and a dealer will probably be cheaper than some backyard shop who has never worked on old CB750)
Get a quote first, if they don't want to do it it will be some outrageous amount, just call around then call Honda, they come down pretty heavy on dealers who refuse to service their bikes, no matter how old
I'm glad you said that. The first place I called when I got the bike was Honda of Jax and they straight up told me they don't work on bikes as old as mine. I figured they were either A) Bullshitting me because they didn't wan the hassle, or B) Were just waaaaaaayyyyy too busy, which I don't really believe because every time I go by there, their shop isn't very full. I don't mind spending a little in order to get the mechanics done right and everything running like it should. I'll be the first to say I don't know a lot about these old engines yet. I just haven't had the time to figure it all out.
I'll see if I can find Charlie, he can do it but not sure if he's still in Florida
PJ
