Weird ignition problem
TripleKing
My son has been riding his 1970 CB450 to and from college classes. This past week the bike will just shut off. He stops the bike and cranks it up and usually it starts and he can make it home. I was working on it today and discovered that when you accelerate the engine to above 5000 rpm, particularly when you gun the engine, it will die. I checked for spark and sure enough, no spark. If you let the bike sit a bit and restart she fires right up and will idle just fine indefinitely, When you acclerate the engine it happens all over again. I have never run across this problem before. Have any of you?
When did you check for spark? Immediately after it stopped running? Also, is the harness and everything stock?
I would test the regulator first. Maybe it's getting overloaded or something? An upgrade to a modern regulator/rectifier is easy and well worth it.
Also, maybe vibration is creating an intermittent ground??? Just some ideas
Rectifier is a new electronic unit. Harness is stock. Could be intermittent ground. Yes, I checked for spark when it stopped running. As of today I have no spark. I will check the ignition and kill switch connections as well.
