weird stuff in tank. HELP
cafebelan
Hollywood Cycles
When I was cleaning out my tank on my 360, which came out awesome.I starting pulling out this plastic stuff,it was all down by the petcock hole.I thought it might be sealer or is there some kind of built in tank filter.Check it out thanks
That, if I'm not mistaken, is the hellish notorious KREEM liner. That's why so many of us scream and shout NOOOOOOO!!!!!! every time someone mentions KREEM.
There are ways to get rid of it - MEK or acetone is known to dissolve the stuff.
+1 for the sealer. I had the same thing on my 550 build. Thought it was corrosion but after a week on the trickle charger and nothing coming out, I took a small chisel to the inside of the tank and POP WENT THE WEASLE! Shit is N.A.S.T.Y.
I've never done it myself, but that's my understanding. Google KREEM and MEK together and you'll probably find lots, and lots of stories about getting rid of this stuff.
KREEM really should be banned :) If you're ever needing to clean and line a tank, there are lots of DIY approaches, and for off the shelf product, POR15 is about the best thing out there. That I've used.
Can't speak to the MEK but POR15 has a stripping product, I think it's like PorStrp. That is some vicious shit but it gets that Kreem crap out of the tank. And I agree with Tim. I have taken heed of all the Kreem warnings so I have never used it but Por is awesome.
just to add, i've had awesome results with a product called red kote! check it out, it works well, nothing to mix, and its red inside your tank which looks pretty sweet ;D
ive just watched a video of Metal rescue being used to clean out the tank, has anyone else used this? and do you need to reline/seal the tank after the cleaning? on metal rescues website they say they do not recommend sealing a tank because of certain additives and its very difficult to remove the liner if it were to start breaking down
