OK, here's a weird one...
I have a '71 CB500 with the Off/Low/High headlamp switch. Recently, I replaced the stock tail light on the 71 CB500 with this unit from Dime City: http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-lighting-parts-classic-style-retro-round-chrome-taillight-62-21514.html. It came with no instructions and no wiring diagram, but it had 3 wires: black, red, and yellow.
My stock tail light functioned perfectly, and had 3 (stock) wires: green (ground), brown (always-on tail light) and green w/yellow stripe (brake). According to forum posts here and elsewhere, I deduced that the new tail light's wires must be: black (ground); red (always-on tail light); and yellow (brake), and hooked them up accordingly.
Here's the problem: it doesn't work. I don't pop a fuse (so I'm not accidentally gounding the circuit, which is a good start), but what does happen is:
1. Headlamp switch to "off" position: always-on taillight does not illuminate when the switch is on or the bike is running, but brake light works
2. Headlamp switch to low or high: taillight comes on w/ switch and when running, but brake light won't work (tail lamp does not get brighter when either pedal is depressed).
The stock tail lamp unit still works normally, so I'm not thinking there's a problem in the wiring elsewhere in the bike. I did recently replace the headlight with a 9" unit from a Suzuki, as well as put on new lower-profile incandescent turn signals, but those units work correctly (high/low/off headlamp works, turn signals work, etc.).
Have anyone seen this behavior before? Any suggestions? Given that the stock tail still works normally I'm thinking defective unit, but I can't imagine a fault in the circuit that would function like described without also popping the fuse due to an inadvertent grounding issue (i.e. the black wire for some incomprehensible reason is actually a hot lead, not a ground).
Thanks a million in advance for any assistance!
