weird throttle bind problem
diesel450
"Fast with a past"
DTT BOTM WINNER
Okay so going to throw this out for feedback.
I recently installed new mikuni round slide carbs, not VM's these are the cheaper version made for atvs. They worked great on a previous 360 build. I am using a new universal dual slide cable from Dime City as well as a throttle body from them. All of this is the same as on the last build on which I had NO problems.
This time its weird. I got the bike, another 360, out for its first shakedown ride and everything is fine for the first 15 miles. In the last mile back to the shop cruising in stop and go city traffic I noticed the throttle getting increasingly hard to turn and sticky almost like it was binding some where. I got it back to the shop and removed the tank. Everything was where it was supposed to be with no binding or kinks anywhere that I could see. I pulled the slides out and the binding was slightly less but it still wasn't right. I lubed EVERYTHING except the slides. including greasing the throttle housing. it seemed to get back to normal but I'm worried that the root cause is in the slides. I did not have a chance to retest the bike on the road yet.
What would cause the binding after 15 miles of trouble free riding? I need to recheck the slides to be sure everything is kosher but assuming it is what could be going on?
I'd love to hear what you all have to say. Also, most sources recommend against lubing the slides. Anyone know why you don't do that. There is the obvious fuel contamanent issue but has anyone successfully done this. Just looking for discussion.
Diesel
I thought of that too, but jeez you'd think it would have happened sooner than that. It was a lot of city cruising this trip, to vary the RPM and make sure the motor took some heat.
Re: weird throttle bind problem
Are they getting sticky at all? I had that issue on a 360 with vm's. You wouldn't be able to see it, but you can feel it. Ended up being a timing issue. Clean the slides, works great for a while then they would gum up after a while and get stuck open or be stuck closed.
That could be. I set the timing but was going to reset valves and timing after like 50 miles. I'll check all that this morning. Your reasoning is that poor timing leaves excess fuel on slides which gums over time, correct?
So, I did not have a chance yesterday to double check the timing, will do that today. But I did clean the slides and bores which were really dirty, and just from handling and the in and out of set up stuff. filthy. They seem a lot more slippery now!
Yeah, bet that's the issue, and yes, bad timing will make the carbs back feed the fuel which eventually congeals on the slides with heat.
Hopefully you got it resolved, but here's another possibility : I bought a VM cable setup from MikesXS for my GR and it would work great, then stick for no apparent reason. Turned out to be a problem in the splitter part of the cable - a barrel end was working loose and wedged itself against the wall of the tube.
