What Bikes have a 7" Headlight Shell?
richm
Hi all,
I'm looking to find a lamp unit/trim ring that I can match up to an old headlight shell. The shell I have is just under 7" outer side diameter (where the ring would meet up) and the inner "tongue" that the original trim ring clips onto is 6 1/2" diameter.
Can anyone tell me what bikes have a stock headlamp that's close to this?
Thanks,
richm
Almost anything vintage British should be 7".
I used a Lucas SS700P shell (at 7") before I switched out to my LED headlight.
Emgo has kits that will fit it, just the metal parts or including the lens assembly to convert to halogen headlight. But, like anything else Emgo, the chrome quality sucks... I used one of the full kits (bucket and rings) plus the add on lens (domed type since the flat glass did not fit the trim rings) on my 98 Savage barhopper. Be ready to replace the screws with stainless versions, and buy a lot of chrome cleaner or save yourself some work and paint the trim ring.
Just an option.
Thanks guys. I'm thinking my best bet is a salvage piece. Even if it's seen better days, the quality is still usually better than some of the new aftermarket stuff these days. If I can get it close enough size wise, I'm pretty sure I can adjust the shell slightly to fit.
Thanks again for your input.
It's hard to say without a picture but pretty sure almost all Hondas cb450 and larger but not the cl models. Cl models have the smaller 5in headlight and I just changed mine out on my build. Also bought the H4 headlight unit with built in led turn signals that perfectly into the cb750 bucket I bought. You can look at my build thread for pictures of it. There is a wide selection of all the components for the 7 inch headlights on ebay, new and old. I think I may have another complete 7 inch headlight unit I have here I'm not currently using also if you need something I may be able to help you out unless you're looking for new parts for it.
Actually I know for sure I have the sealed beam bulb out of the one I just took out to put on my bike. I haven't tested it to see if it for sure works but I can if you're interested. You can have it for the price of $FREE.99 plus shipping if you want it.
Just to clarify he's looking for the trim ring to mate with the bucket he already has. With a little ingenuity a simple 7" trim ring should fit. The Honda's had 3 bolts spaced evenly around the bucket which threaded into tabs extending from the trim ring into the bucket, if I recall my CB750/500/550 days. So that might be an easy thing to make fit - just need to drill 3 holes in the bucket to line up with the tabs on the trim ring and you have a nice secure fit.
My aftermarket Emgo Lucas replica has a tab A slot B sort of arrangement at the bottom and a single tab/screw at the top to hold it in place. More difficult to make work given the hole tab thing at the bottom of the trim ring would need a slot in the bucket - difficult to cut and would be weak if the bucket is plastic.
I'd shoot for a 7 inch Honda trim ring to try. Should be plentiful.
Yup. He may have a honda shell though too. Just those measurements given aren't quite enough to tell what it actually is that he has... you're correct on the installation portion of the hondas and if his already has those 3 holes there then he's golden... it's really hard to tell what exactly will fit and be the easiest without seeing a picture.
Really is model / year specific. My '80s Hondas have locking tabs that you engauge the trim ring off center then "twist" it a few degrees straight to lock it in then a single screw keeps it in place.
It's aleady been said about the Emgo quality but here is what I bought for my 7"er off ebay for about $30
I believe my CL360 is that size. I bought a new headlight as the last one's back was all dinged up. I can measure it tomorrow but if you want it PM me. We can figure something out.
