What clip ons to get?
joecar
I have a cb360 and I was unsure of the fork size. I took a micrometer at it measured 28mm around. whats a good pair to get?
Www.roccitycafe.com sells adjustable ones, and he's a member here.
I'm really curious as to what forks you have on. 28mm is REALLY small for a cb360. I have an old CR60 dirt bike that had 28mm forks- and it's basically a pit bike.
just understand that after u put on clipons.. especially adjustable ones... it will take u a month of moving ur bike around before u trust them.. i can't tell u how many times i was leaning my bike for some reason holding on to one grip with my other hand mm's away from the frame waiting for the clipon to fail...
that did cross my mind too, hahaha
also I took a couple pics of the forks becuase I cant find out what bike these came from. But I did go through the book of reciepts from the previous owner and their was a triple tree top from a cb400f and fork seals purchased from siriusconinc.com part #FS334611. These seals say they are for HONDA CB360 CB400F CB400T CM400A CB450 KZ400. HONDA FORK SEALS 33mm x 46mm x 11mm Part# FS334611. Am i measuring the forks wrong? I know he went with a drum brake in front to keep an older look but I cant remember if he said anything about the forks.
You're measuring them correctly, but you're looking at the micrometer incorrectly. The 0 at the bottom is correctly lined up with 33mm. I'm guessing you were looking at the inside of the caliper currently lined up with 28mm?
The top triple purchase and fork seals make sense. The triples are interchangeable with that model as well as others, and it's common to see them crack.
I put the roc city adjustable set on my 1974 CB360 and couldn't be happier. If you are currently riding the stock set up, you will be blown away by the better handling. 33mm is what I used. For the level of quality, I think they are a steal.
