The clutch can ground the solenoid without lighting the neutral switch. The diode isolates the neutral light from the clutch switch. Both the neutral light and the clutch ground the solenoid, but because of the diode, only the neutral switch can ground the light so it lights up...
The diode is that small rectangular, 2 prong little black thing, on the right coil, front.
Any diode that can handle 12V, 4 watts will do...They rarely go bad though...
