what fork set up fits 175
supercafe
Coast to Coast
whats up.
i recently went on a 250 mile road trip, and found my self with a problem after a really bumpy road.
i blew a fork seal, now i know i could just re/re the seal, and i do have a spare set of forks. and was going and still might
put the other set on, but i was wondering what other set would fit my cd 175 same set as a cb 175. if i were to do this
i believe that it would stiffen up my frt end. which would be great, because at 85-90 m/hr going around a corner it hops
abit.
if there is any one out there that could help, that knows what could work let me know. would be a big help, i would like
to do it soon for the ottawa dads ride and i have a couple shows coming up..
any way thanks.
later.
thanks hot rod troy.
the chart has some awesome info, so the cb 175 is tube size 31. so any of the tubes in the list with 31 tube size will fit????
thanks for the link.
later.
thanks.
nice to hear some has worked on these bikes.
i have another stock set to use, but just wanted to see if i could stiffen it up. sounds like alot of trouble for no reason.
but what would you do to stiffen it up?????
can i replace the inner springs, and with what?????
any way, thanks for the info, it helps out alot.
later.
man,
thanks alot.
i am going to do this on my spare forks and see how they work.
i do really want to get a stiffer frt end, and believe this could work awesome.
i'll let you know how it turns out, and i might be pm'ing you for questions and info to get this right.
this would be cool if i can get it right.
thanks again man.
later.
Why not use heavier fork oil? It's a standard fork tuning trick...is there something weird going on with the CD/CB175 forks?
hey guys,
thanks for the info and responses.
i believe i am going to rebuild the spare set and see what happens.
i do have a question, my manual does not tell me what fork oil to use.
what should i use, for a 175???
thanks again,
later.
That's wacky! I must have been wasting the 4 years I spent building suspension for roadrace bikes(never mind 30 years of doing my own work).....including forks. Even them ol' damper rod pogos. Fuck man, I don't know what I would have done if you hadn't pointed out my total lack of knowledge. Thanks man, the world is a better place now.
back on track.
Sounds like you didn't have enough damping to keep it from bottoming out....sound right? At least that's the impression I get from what you've written. If so, you can indeed run heavier fork oil to firm up the damping, especially since this is a CD175 I'd bet you're not out jamming it at 100mph thru a canyon, you are probably perfectly suited for exactly this.
If you don't already have the specs for the factory setup ei; weight of the oil, level etc. find them.
If you're springs are OE then chances are they are pretty well shot. You can kludge a bit extra by cutting a portion out (a matter of an inch or so...it'll depend on your bike/needs/weight/cheapness etc) and adding a spacer of the same length. That effectively makes the spring stiffer since you're applying the same force to a shorter piece of wire. Coil springs work the same way a linear torsion spring does, by twisting the wire. Ultimately, a set of fresh (if you weigh 100lbs+/-) or preferably good aftermarket springs are going to do you the most good because you'll maintain the full wheel travel without having to worry about coil bind from excessive spacer length.
Now that your springs are (at least nominally) more suited to the weight, you WILL want to firm up the damping.....by using heavier fork oil. Stick with me here, I'm not talking about a massive increase over OE, but going from say 10wt to 12wt will make a noticable difference in control and comfort without making it ride like a 2x4. If you're serious about getting good action from your forks (and you should be, this is pretty cheap to do), you may want to buy some varieties of fork oil and mix/match weights to get exactly what you want. Again the change from OE doesn't have to (and shouldn't) be very large.
Now, if you want emulators for those little forks I can help you out there but that'll require a little more money as I'll need to fire up the lathe for it. No biggie.
You may also want to think about adding shraeders to the fork caps. It's pretty amazign what 2-3psi will do once you're all built and dialed in but maybe you're carrying a little extra weight. Keep in mind, some forks are more likely to spit out the seals under pressure, as you've found out and you may need seal rings to help them hold up. I dunno bout your forks specifically, perhaps the offending seal wasn't fully seated?
If you are lucky enough to have pass thru triples top and bottom there are a few options for swaps but if you're going to flog it you may be better served with something with a larger diameter. Even just bumping up to 35mm will make a world of difference.
I hope this helped a little. If not....well.....sorry mate.
ps: I blame the typos left here on Guinness.....
hey guys,
i really appreciate both of your wisdom!
you both seem pretty knowledgeable on this topic.
i did'nt mean to start such a steamy discussion, but it is helping with my questions.
i am going to take from both of you on this.
i am going to rebuild my spares and cut and space them, and try the oil trick. this should be, i believe what i am going
for. i just want to stiffen up abit, if and when i go to race it i'll re/re the tree and forks to a bigger size.
as for know i think that this should do just fine.
well thanks again, and i will be calling on you guys for info when i get on this.
i ordered the seals and ran into other problems, my cam chain well actually i think the tensoiner went on it. now
i must pull the head off and see!!!!
luckly i have a spear motor, not running but hope it is good for the parts i need..
any way thanks again,
and i'll keep you guys up dated.
later.
supercafe said:
whats up.
abit.
any way thanks.
later.
Hey Supercafe!
For my CB175, I just changed the fork seals and put in some 10W oil VS the 5W that is in there stock. Effectively, that stiffens up the dampening. With clubman bars, there is more of your weight in front. It's also good to get rid of the old oil since it will probably look like water or worse... Like in this video
[youtube=425,350]http://www.youtube.com/watch?v=otc7VaAiFGA[/youtube]
I find the heavier oil made it stiffer and dampens much better than the old oil that was in there.
hey,
thanks mangnag,
i am going to change the oil, to 10w.
but also on the spare ones i am going to cut an space the springs.
the performance is alright with the new oil?????
how much did it change the ride????
thanks for your input and how goes the cb build???
later.
Hey man,
Build is going good. I've been out and riding for the last 3 weeks. I got almost everything I wanted done, except for the rearsets. I went with the EMGO shorty mufflers and they sound fantastic. Loud, but not too loud. I also think my Clubman setup turned out pretty well, I managed to run the wires inside and found the right bars for the size of bike. Still a few things I need to do: Make a fork brace out the the fender, rearsets, cover up the cables and run them better...
The bike's got some go around the city, but I still hit a wall around 70MPH. Jetting is good now though, it runs well at full throttle. Next I will the replacing the 40 year old ignition coil / wires/ caps and doing the coil mod.
Here's a quick picture:
Let me know what you think if you have any suggestions. I wanted to keep the original looks somewhat.
nice man,
looks great, what type of rear sets are you going to use??
i used a gxsr and r6. it makes it fun, and i installed them where the rear pegs go. with my seat perfect fit.
mine needs alittle tuning but it ran good, i acually had it full out at 100 mpr for about 10-15 sec or so.
thats what the speedo said, i might be of by 2-4 kms. but for regular riding, 65-75 mpr no problem, it can
even pass people (lol).
any way bike looks good, and hope you don't run into the same probs as me!!!!!!!
thanks
later.
