What is cost to do your own cafe seat?
cjrenick
72 CL350
Just wondering what kind of cost one would have for materials to do a fiberglass cafe seat? I have found a seat for $75 and just thought if the material cost was close to that then I would forget about making my own.
If you are starting from scratch with no materials at all, the final cost will most likely be over $100 (depending on the cost of materials where you live). If you're looking at it from a purely cost angle, definitely go with the pre-made one, $75 is pretty cheap.
$40 to $50 cloth and 1 gal. resin, $5 for paint and sandpaper plus you need foam for a form then a pad could be $25 and up
My frame was about $20 bucks in materials but the gel and leather from the upholsterer was a whopping $250 bring the grand total to $270. this is likely on the medium to high side for a custom build.
:o If you can find a style and a fit that you like, then buy it. If you are making a unique show bike then make it.
The ABS plastic seat I made for my RD cost over $3000 but it is the only one in existence like it.
Cheap and decent option is to get an old tank that's dented up in front from a scrapyard (local guys sell 'em to me for $5 or $10), cut a bump out of the rear part, and weld or bolt to a 1/8" or 1/16" piece of sheet steel, cut to fit your frame. $20 pan, rest of the cost depends on how you want to cover it and with what, paint, etc.
A seat will cost you more then $75 and take a bit of time but saying you made it yourself is priceless haha.
Everything I make I usually make a mold for so if I want to make another one, it cost me about $25-$40 to do so.
Its cheaper to buy that $75 one.
You have to include costs for whatever you use for a mold (flower foam for me, 25 bones)
Plus resin, matte, catalyst, paint brushes, sand paper, Containers for mixing in, bondo or some sort of filler, etc.
It adds up real quick. Mine was just shy of 150 for quality materials from a fibreglassing specialty store.
Dont forget, the mess and time is huge.
Im buying one next time.
Is that supposed to be three HUNDRED dollars?
Do you have access to a welder?
If so I made a seat out of sheet steel with zero experience before (making stuff out of metal or welding). Total cost about $20
I thought we were talking about a seat, like the soft thing under your butt? if we are talking about seat and seat pan I need to revise my estimate! :)
Nope, $3000. Its a complete 3D FDM print in ABSplus material with brass threaded inserts. The parts were then smoothed and strengthened using vapour smoothing. The rear cowl is complete with a removable door for storage. I should really take a picture....
[/quote
Great. I'll give you $40 (double your money) for one that fits a CB750 or a CB360. I'm not picky.
Funny bugger ;)
My times got to be worth at least $8 on top too :D
Not 100% sure but the pan took about 1 hour of fiddling, another hour to measure and cut the segmented section. Probably a few hours in welding it all together and then maybe 30 mins with hammers and dollies to round it out a bit.
6.5 total maybe. Sure it could be done quicker but I was just making it up as I went along.
I need to see a 3000 dollar cafe seat.
The seat is modular since the tank will be changing in the future.
[list type=decimal]
[*]solid ABSplus material (like ABS/PC)
[*]front section incorporates a ram air scoop
[*]front section can be changed out to match new tank
[*]the seat is currently raised up in the rear to clear the stock oil fill
[/list]
how you put the upholster into the seat pan?
