What is the max Cylinder Head Warpage for a CB200
Texasstar
Can't is a four letter dirty word
Does anybody know the max head warpage for a cb200T?
I don't know of any numbers but it doesn't look that bad in this picture. Are you sure the surface it is sitting on is 100% flat? Is that picture of between the cylinders? If it is that would mean the cylinders would seal first when tightened.
Torquing it down to the case with a good gasket between it might be okay.
Just my opinion from what I can see. :)
Thanks this piece of granite wasn't perfectly true...checked it with a steel square then used the square on the head with feeler guages...no gaps.
I'll have to look it up but I think it's some crazy number like 0.022"
Looks like someone didn't follow bolt tightening (or loosening) sequence
Start in the middle when fitting, around the outside when removing
