what master cylender to buy
bradj
Over 1,000 Posts
DTT BOTM WINNER
I am running a twin brake set up on my 71 cb500 with stock 550 rotor and calipers and stainless lines i bought a ninja mc and i did not work at all I put a f4i mc and it was better but not great I do not want a crazy remote res. master cylender off a some 09 space ship looking crotch rocket used is fine I just DO NOT want to have to rebuild 30 year old goldwing parts does any one know what late 90's early 00 bikes that the master cylender will work for me with looking as stupit as new school mc please help this is my first bike and is this is the last thing on a year and a half project thanks brad
Bradj, I can't really tell what you are and are not looking for. Could you post some pictures of what you do want, and what you don't want? And please, for the love of all things good and true, use at least periods. I can barely understand (honestly, i'm not sure if I understood it correctly or not) what you said.
I read it a couple times - what he's looking for is:
A good, working master cylinder that will drive a dual-disc setup on a Honda CB500. He does not want an old Goldwing or other old MC that will require a lot of rebuilding (I presume a perfect one would be acceptable) - he'd rather have a more modern good working master cylinder, but one that doesn't look like a super-modern unit.
You can buy brand new ones from www.mikesxs.net
http://www.mikesxs.net/products-71.html#products
Go about mid-way down the page and you'll find something called Early Dual Disc Master Cylinder. Would probably be perfect for you. Looks just like an old Honda master cylinder but is brand new and has a big 22mm bore for dual-disc setups.
I may have got the ninja master cylender to work tonight, or at least work better. I ll check out the link you gave me just in case, thanks Tim.
22mm sound way too big for honda. Standard single for single disc is 14mm and for dual 16mm.
http://www.vintagebrake.com/mastercylinder.htm after seeing this and some discussion on sohc4.net forums, I bought a modern 14mm nissin master and the leverage seems to be enough for dual discs, but I haven't had possibility to test it in "live" situation.
What would be the harm in using too big a m/c? I get not having enough hydraulic pressure for dual discs with a smaller one, but can you have too much? I've never really done much reading or thinking about this so I'm kinda curious.
The bigger the master cylinder is the more you need force and the lever feels too stiff. With too small master cylinder you run out of travel.
