What to do with Bolt/screw holes when painting an engine?
Modgod1
1974 Honda CB550 Cafe Racer in Progress
I'm going to replace most the bolts when I've finished painting the engine, what I need to know is, do I leave the old bolts/screws in when painting, or should they be in half way, or out completely, and if so what do I fill the holes with when painting the engine?
Thanks
If the bolts are all the way in and you paint and let dry you'll most likely pull paint with it. A bolt half way out wouldnt be to bad but when you go to remove turn it in a few time to losen the dried paint befor removeing it . And when i was doing my motor i pulled the bolts and placed wadded blue tape in the holes lil paint wont hurt . When dried take a pair of needlenose and pull the tape out !
Thanks, yeah I should have thought of that, that's what I'll do!
I went to a big box hardware store and bought a bulk container of little foam ear plugs. I painted the engine and frame using them to plug the holes. Wait for them to expand and slice them off flush with a razor blade.
Re: Re: What to do with Bolt/screw holes when painting an engine?
This is a great idea!!!
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
