What to remove from CB360 frame?
Hetzer
I have a 1974 Honda CB360 that I am getting ready to turn into a Cafe Racer. I am about to strip it down to the frame, and I was wondering: what all do I cut off the frame?
We can't tell you that. You need to decide what you want to keep and what you want to be rid of.
There's no step by step cafe race cookbook.
Obviously not, but I was wondering what are the things most people remove? I'm new to motorcycles.
first thing before you cut anything off the frame is where will all your electrics go including the battery.
most of the electrics are fixed on tabs welded to the frame which are normally cleaned off and the electrics move in a box somewhere(often these get simplified).
second what gets normally cut is the rear end of the frame and gets connected with a loop.
i have no idea what you plan to do but let me give you something:
you dont want to ruin your project|frame by cutting the wrong stuff off
you dont want to destroy the integrity of your frame
you dont want to reweld any mounts or anything which you cut before
working on the frame must be well planned.
take your bike apart.box everything.document everything.take fotos.
may the force be with you.
plus be careful with what you do:
nuts and bolts will crack
these bikes are old and parts are hard to get
you dont want to search 3months for a part which is discontinued.
go easy on everything.it takes time.
got 2 friends which tore apart their bike in 1 night,no documentation no plan nothing.
now they are stuck.
organisation and diligence is evrything man.
learned it from failure.
xb33bsa said:
cut the center stand brackets off first 8) they are heavy and useless on a calf racr
I prefer to keep the brackets and remove the stand. It's nice to have the ability to throw it on. Something tells me this guy doesn't have a pit stand laying around
The guy I bought my build-a-bike cb360 kit from had already ground off all of the frame tabs in the triangle, besides battery mount (thank god) he had also ground the gauge mounting brackets off the triple tree and the horn/brake switch mount off the front of the frame. I had to do all the cleanup, but he'd already made the decisions. I would have left them all, personally.
If you're looking to keep it simple (and I would for a first bike)
Keep it all. Stock intake, side covers, etc. Modify the seat pan and maybe do a rear hoop. I think a poorly executed brat/scrambler look better than a poorly executed cafe, and is invariably more practical.
this +1 this is good ad-vice,think outside the box
and i was joking about the stand brackets,keep them !
keep it stock airbox battery electrics etc
modify the stuff that matters
lace up some aluminum rims next size wider,put on good quality tires
get some GOOD rear shocks,service forks, kit them or upgrade to 35's
go thru the brakes new frictions etc
superbike bars, seat to taste
RIDE IT !!
