I've seen this question asked in various ways across the interwebs but none of them seem to really get to the heart of what's going on with these. Usually the discussion devolves into specifics of who uses what on which model with no real specifics as to how they arrived at their conclusion.
But from what i can gather on another thread,
http://www.thumpertalk.com/topic/888059-needle-jets-bleed-type-vs-primary-type/
So what's the real difference between a Primary-Type (p-type) and a Bleed Type (b-type) needle jet?
They say typically you use P-type with 2stroke motors and B-type with 4stroke. Which means...nothing really.. Typically? Says whom? Has It just been that way since the dinosaurs?
From what i can gather the rationale behind this is that on a 2stroke you spend more time in the larger throttle opening ranges, where on a 4 stroke you spend more time in the <50% throttle ranges (traffic and such). and that because of this, B-type jets are typically leaner up top then P-Type which may be richer at >50%.
Also, atomization of the fuel. Better, more appropriate atomization for 4stroke on a B-Type
If this is true, then isn't it really a simple matter of picking a B-Type when you need a bit leaner but don't want to go a full size down with the P-Type?
And furthermore, if this is really true, couldn't you just pick a wider needle instead of moving to a new jet?
So there has to be more too this than simply "leaner vs richer".
Either way, this is creating some dissonance in my understanding of how these actually work and when to use one vs the other or if they are simply not interchangeable.
For a case in point, my Vm30s came with P-Types. Why? Isn't the application typically(my assumption) for 4stroke motors? Seems silly to think that the good peeps at Sudco wouldn't know the difference.
anyway thanks for the discussion
jeff
jeff
