Wheel questions CB400F
neevo
Over 1,000 Posts
Can someone provide some expertise/inputs for my wheels?
Currently have a complete front wheel, spokes are ok and rim has a few dings and bit of surface rust. Rear wheel is cactus, rim is bent and I took to the spokes with the grinder as they were shot too.
Ideally I want Akront style deep rims in black, what options do I have?
1. Clean up front rim, get new rear rim and powdercoat both. Fit with new SS spokes.
2. Get new deep rims and spokes, powdercoat
3. Get new deep rims already black, new spokes
Lastly I like the look of modern sportbike rear wheels, wide rim, fat tyre. I assume stock is 2.15, how much larger can I go that will fit a nice wide tyre without clearance issues?
Absolutely lastly, where is best to buy? Buchanans looks the goods but it's going to cost, arguably the most expensive thing I will be doing :(
Stock front is 1.6" wide, rear is 1.85" wide. That's not to say that it hasn't been changed out though.
Sometimes you can find an alloy wheel on ebay and they are asking a decent price for it. New wheels / spokes are always expensive.
Can I get a 2.15 or larger on the rear?
This is the look I am after (within reason):
Prepared to buy new if I have to, certainly offers the chance to go up a size or 2 on the rear.
Sure can - check this page out:
http://www.oldrice.com/Cafecorner.htm
While the project is old (last update 2002), they were doing some good stuff. Just be sure that whatever tires you are looking at will fit the wheels, come in the proper sizes, and are made for "front" or "rear" fitment.
I'm using WM3 front and rear on CB360's (same wheels as 400f)
Ideally I would use WM2 front and WM3 rear but don't want to pay the extra for WM2 rims
If you use stock hubs you need 36 hole rims, if you swap to CB450,500f 550f or CB750 they use 40 hole rims
Black flanged rims just don't look right, even if constant polishing is a PITA, it looks better
If you want black, get smooth rims (MX rims are relatively cheap in 36 hole)
Thanks PJ, good to know I need to look for 36 hole, is the pattern pretty standard or are there variations in 36 hole I need to watch out for too?
Didn't think about whether a black shouldered rim would look ok, thanks for the heads up. Will be looking for some standard rims then, helps keep the cost down anyway.
BTW definitely still keen on those carbs if you can help me out. Seems they are rarer than hens teeth.
There are differences based on the hub.
If you get MX rims the hole diameter is larger than stock Honda nipples so you have enough clearance.
You will need nipple washers to go with MX rims
I can make you a set of 72 for $25.00, there are pictures in my 360 builds
Here's link so you don't have to hunt through 20 pages ;D
http://www.dotheton.com/forum/index.php?topic=11736.125
a xs 650 yamaha rim(rear 36 spoke) will work for both front and rear(front drum models) stock honda spokes as well, will lace up
PJ,
Just looking through the links you posted as I am looking to sort the rims out on the 400 in Feb. Can you give me a bit more info on what you did for yours so I have it straight?
1. Looks like you went with the same rim front and rear, is that true? If so whats the benefit? I like the look as it toughens up the front nicely.
2. Whats the width of the rear? Can I go larger on the rear? I will be keeping the stock 400F rims (disk front, drum rear).
neevo said:
PJ,
Not sure what you mean here?
Don't fit oversize tyres to stock rims
Did you mean your keeping stock hubs?
I did post about parts of wheels, rims are just the outside bit that holds tyre
I used WM3 front and rear rims because it's cheaper than getting WM2 alloy for front, plus, you can fit any tyre from a 90/90 to a 120/90 on it (3.25"~ 4.75")
Stock rims are really max of 90/90 front and 110/90 rear (and that's a bit oversize on both ends)
80/90 and 100/90 would be better on stock rims (3.00" and 3.50")
People fit massively oversize tyres and think it's OK ::)
When they try correct rims for tyres fitted, they find out just how much better handling is
I would like to get a 2.50 (WM4) and a 3.50 (WM6?) pair of rims, just don't want to pay $400+ for them ;D
Hey PJ,
Sorry if it wasn't clear. The only part I was keeping was the stock hubs.
I liked the look of your rims, especially the tougher looking extra width and was wondering:
1. What the front was size wise
2. What acceptable width I could put on the rear to fit a nice low profile wide tyre too (going for a mix of classic and modern with my build)
Thanks
That's a huge jump from 1.6 & 1.85 stock rim width. Do they fit without modification?
neevo said:
Hey PJ,
Thanks
No idea, can't afford them to find out ;D
I wanted them for XS650,I know the width is OK on that bike (with offset sprockets)
Rims are WM3, 2.15" internal across flange, about 2-7/8" on outside of flanges
WM3 front is no problem, you could possibly fit a WM4 (2.50") rear but no real advantage as swing arm /chain line wont allow a real wide tyre (I have no idea if the 4.60 trail tyre I bough will fit in 360 swing arm without modifications ;D )
I wouldn't fit really wide rims to 400f, don't think you have enough clearance front or rear?
No probs PJ. Is it better to have the front smaller (WM2) or could I put a WM3 front and rear?
I like the aesthetics of what you did.
I am up for new spokes and rims anyway and the price difference between the 2 & 3 is negligable.
Sorry for the multiples q's!
If you getting rims from Buchanan's the price difference isn't too much, may as well go with WM2 front.
It does limit maximum tyre size, 90/90 is the best fitting if your interested in good handling rather than looks.
400f can handle a bit strange with oversize tyres (I once watched my brother sliding down the road at 90+ when his 400 threw him off :o )
WM2 & WM3 it is then :)
Still a tougher look than stock and will drop a 90 x 90 on the front so I get the handling benefit.
..........................and a 110/80 or 90 on rear.
It will handle very well as long as shocks, steering bearings and fork seals are good, no need to 'shut off' for most corners as long as your around 85~90, just lean it over ;D (seems to work for me ;) )
