Wheels wheels wheels...
boomshakalaka
Over 1,000 Posts
So I have 2 sets of wheels, one is twin drums and one has a front disc. The twin drums have rims that are for sure bent. The front disc is true to the eye. The other rear drum seems true to the eye however there is a lone bent spoke. The logical conclusion that I keep coming to is that if all the spokes are tight yet one is bent that something had to give, namely the rim.
-So if theres not a flaw in my logic, is there a way to salvage this rim?
-I want to run twin drums, can I lace the front drum hub from the bent rim into the front disc rim with OEM spokes, or are the two rims different?
-I've seen sets of 10 spokes for something like $12 shipped on ebay. Can I use these to simply replace bent spokes, or is it bad to mix new and old?
Your best bet is to measure the run-out.
Use an old swing arm or pair of forks and clamp them to a bench. A $10 dial indicator is all you need. Also check visually.
I've seen spokes bent with the rim and hub being fine.....you may be ok..
