When good pistons go bad
450cl
Active Member
This was the first bike I ever bought. Rode for two years and then she died. Stayed in storage for ten years! Now its time. Im going to be looking for pistons and gaskets. Any suggestions?
Wow, that's some nasty damage. Were you running lean? I've heard of lean conditions causing issues like this. Besides the pistons, looks like you're going to need another head as well. Also, if it was me, I'd tear down the entire engine and clean it, just to make sure there are no piston remnants kicking around in the guts of the engine and the oil passages.
Keep us updating on how it works out.
the head should be fine, the piston definately melted due to lean conditions (so make sure you check out those carbs).
if it were me id just get new pistons and rings and bore it.
Yep, new pistons and rings for sure. The head, I think it could be cleaned up. As far as what caused it?... Would parts be available(pistons)from a Honda dealer. Already found the gasket set.
ebay man....your probably gonna have to go 3-4 sizes over to get rid of all the gouges in the cylinder walls so id bring it to the machine shop first and see if they can tell you what size pistons to get.
$30-$40 would be a good deal if it includes boring / honing (which it should). I've paid about $50 typically. But make sure you have your new pistons before you go having things bored. The machine shop SHOULD measure each new piston and bore the cylinder to match. Pistons are all slightly different.
of course....BUT he should bring the jugs to the machine shop before he orders pistons to find out how much material must come off the walls in order to get rid of the gouges.
since your in there why not go over to bore tech and get a set of their 1 or 1.5 over pistons...
might as well get a little boost in performance if your doing the bore. Plus with that kind of overbore, no worrying about if your cutting enough material to get rid of any guages.
and the non stock pistons are lighter for a faster reving motor!
What rocan said. If you are going to do get work done to the original cylinders then you may as well go all out on it with a 1 or 1.5mm overbore. Get some good pistons to match and maybe even fit some 2mm oversize carbies. Jet to suit and perhaps advance the ignition timing just a tad. 2 degrees would do it for a mild performance mod.
Then, add some sweet 2-1 pipes and performance aluminum cans and and and and and....
Ok, all better now. ;D Seriously, the overbore is a good idea.
Cheers - boingk
Agreed, if Im sourcing out the machine work. Don't see why the price would change for a larger overbore.
Never had to buy a piston any suggestions on manufacturers.
Bore Tech has em...
http://www.bore-tech.com/HondaPistonsRings.html
Team Hansen also has them. Great guys over there.
http://www.teamhansenhonda.com/parts.htm
Look about half way down the page.
Ouch. Yeah, that's a lean burned piston right there, pretty much confirmed by the deposits in/on the combustion chamber and valves. Whilst taking care of the pistons adn bores, I'd strongly recommend doing the valves and seats as well. That kind of hot metal flying around pressure welding to other metal bits WILL wreak havoc on your valve's ability to seal. It' be a shite deal to get the engine buttoned up and THEN findout you're not holding compression. Been there.....
In my experience, machine is set for a single bore, usually 0.010"~0.020"/(0.25~0.50mm) finished oversize
If your going bigger than that you will probably get pro-rata on boring (beacuse cylinder is already set up and doesnt need re-centering)
Its really unusuall NOT to charge extra for larger bores, you can only take so much material out per pass without risking damage to machine or cylinder (particularly with pressed or 'shrunk in' liner)
If machine shop screws it up they would be liable to replace parts but may tell you its at your own risk if your trying to get it too cheap.
There are many real good machine shops out there, but, unless they have experience of motorcycle alloy/cast iron liners be veery careful
PJ
I think PJ is psychically sending you the info, however forthose of use who aren't ESP equipped.....
If you're within specs or at least within factory overbore specs, factory pistons will probably sit you fine. Ebay or your local stealership are a good option.
If you're building a performance engine then there's lots of manufacturer but I likie Wiseco
http://www.wiseco.com/
Gotcha PJ. Spoke with a good buddy today who also said the same. Try and keep it within factory overbore. He also said, those preformance pistons would yeild little results. May not be worth the extra buck, would you agree.
Bore-tech.com does have alot to offer, thanks Kanticoy.
