Where to buy cables?
Deviant1
Over 1,000 Posts
The clutch cable snapped on my cb750 the other day. Normally I'd just replace it with oem, but my clip-ons require the cable to be shorter. If I can find somewhere to order custom length cables (not bicycle cables though.) I'm going to order shortened throttle cables as well. I checked with motion pro since they are who I normally order cables from. I couldn't find a place to order custom length cables there though. Thanks in advance.
I thought you had to send an OEM cable to Motion Pro and they shortened it?
I know Les Barker had / has some shorter cables for popular bikes, but he probably couldn't get them to you fast enough.
See I was thinking more along the lines of sending measurements to a company and having them make me a new set of cables to my specs. Surely someone does that right?
The ends and adjusters are pretty standard on 1970's Honda's, you can probably use clutch cable from smaller bike (CB350, CB125, etc)
they are not usually 'lighter' construction, just shorter.
I'll measure CB350 and CB360 clutch cables tomorrow
PJ
Im pretty sure motionpro will do a custom length cable with whatever ends you request. Do you have a local motionpro distributor? Maybe go in there and ask them about it.
For work, I go to a generator/alternator repair store. They also sell/make cables. I'm thinking about getting my front brake and clutch cables made there. Take a look around locally, it might be easier to have the bike with you when your doing it, that way you can see whats being made rather than trust somebody 1000 miles away trying to read somebody elses scribble. It is a little pricey, but I like to support the local guys, too. ;)
