surffly said:Things depend on what F you have.
There are two different sohc Fs and at least one DOHC.
No market for HC pistons at stock bore.
No real point to putting pistons in a motor and not at least going to the first over bore.
Finnigan said:What are mods for the 78 head?
Valve angle is identical to the K's....the F2 valves were sunk to make room for the larger valves. The F2 port is much better than any K as it starts out 2mm larger in regard to cross section. The long side...especially behind the guide.... is much, much better. I have had 5mm valves made for the F2 for an LSR engine but they are still heavy if you stick with the stock tulip. I am sure F2 5mm conversion valves will be available in the future with a different tulip.mlinder said:I've seen more than a few people switch to early K top ends with wiseco 836 pistons, that might be because a while back they didn't even make big bore pistons for the F.
They require different pistons because the combustion chamber is shaped differently, and K piston actually drop compression when paired with an F head.
From what I remember, there's something about the valve angle on the F's that cause the valve guide wear.
MR915 said:Valve angle is identical to the K's....the F2 valves were sunk to make room for the larger valves.
Yes it has been Markmlinder said:Ah, well there you go. Been a while.
Hiya.![]()
