Which bars on my CB750?
Yamanube
I am looking for a set of drag bars but am running into a problem with length and clearance. My forks are slammed up into my tripples like 4 inches, I like the look but don't really want to go through the work to cut them down and would just like to run them sticking out right now. The PO bent a custom set of drag bars that bend right after the clamps and clear the fork tubes BUT he cut them too short so when the brake lever assembly is installed the bars only protrude into the throttle tube halfway...not super comfortable with that so I want a longer set of bars. Anybody know where I can get bars that will work? The Cyclexchange drag bars look like they would clear the fork tubes but I am not sure they are long enough, I think my bars are 26"-27" end to end.
Why not just weld a little more 7/8 tubing on to the end of your bars? Sleeve it with a smaller piece, run a bead around it, grind smooth, and BAM! Problem solved. Would be way cheaper than new bars, and you know they will work.
That was my first thought but wasn't sure if it was the best option. Now that somebody else suggested it I think I will go ahead with it. ;D
the slam looks good... but check the clearances. and that rear end better have at least a 3 inch drop.
and i sure hope those pipes are baffled.
IMO those tubes sticking out the top of the tree look pretty stupid.
How about shortening your forks internally?
No need to cut the tubes, just the springs ;)
I don't think they look stupid sticking through, I kind of like it! But cut off would look good too! Thats your call!
yeah thats what im thinking....
btw i just saw you selling those pipes in the for sale section. i guess i can rest easily tonight =]
LOL yeah those pipes had to go, picked up a 4-1 setup with a baffle. I don't really like the fork tubes sticking up out of there but I don't really mind it enough to do the work. I plan on bringing them up a couple inches before it hits the road.
