Which jets on my CB500?
jwarriner
Ok, so I asked over at SOHC4 and got complete shit answers. One guy answered "yes, you will need bigger jets." No shit. Thanks for nothing.
I am either going with #105s or #110s. I have both. I just want to know which would be a better starting point.
I'm running the stock air plenum thingy with a K&N on the back instead of the stock air box and filter. Most people claim that this does not require a jet change.
I'm also running an exhaust system that isn't your average MAC piece of shit. I've attached a pic. As you can see the runners are a little longer before the collector and the muffler actually seems to be a quality piece. Not sure of the brand. Got it off ebay as a NOS item that is from the 20th century, probably before the 1990s. I figured going to something like this might warrant the increase to 105s.
I think overall the 105s are the better choice. I am afraid the 110s will cause a rich condition. Does everyone concur? I am keeping the standard #40 slow jet in either case.
Plug chops man my 500 ended up with 29mm kz900 carbs and 115's in it so many things affect it sea level whats done to the motor how restrictive is the muffler your air filters needle clip positionyou should start with the big jets and work backwards a temp gun helps this is the reason i refuse to own another 4 cylinder good luck and sohc4.whatever sucks
Yeah, I have three of these four cylinders. That's 12 fucking carbs. I need to sell one of these and get a 2-stroke.
I have a temp gun. Is there a guide for using it to tune?
My air filter is a K&N without the box and should breather a little better than stock with the box.
No idea on the muffler. None whatsoever. I just know it sounds pretty rad. It sounds 3000 times better than my CB550 with no muffler. I'd like to imagine that based on the design there would be a little bump in performance but as we all know Honda did their homework and made about 50hp/liter, it's hard to imagine that being improved on without a lot of R&D.
I am not at sea level. Riding will be done at 5000-6000ft mostly.
The more free the air moves the more fuel you need to slow it down lean bikes are fast and hot they will hole pistons quick so if you shut the bike down at wide open throttle un a up hill pull and check a plug you want it dark brown if its to light in color or white go up a few sizes jet sizes are in 10's so 105 to 110 isnt a full size its a half
Just a few random thoughts:
Pipe: that one looks like teh headers are too long to be effective at most revs and I have no idea what's inside teh muffler portion, so now way og guessing what the effect of that might be.
Filters: K&N behind the airbox seems to use stock jets but pods usually run leaner at most speeds.
Altitude: 5,000 - 6,000 ft usually results in a need to run leaner than stock to match the thinner air.
How to add those all up is the biggie. I'd start with one up from stock main jets and do a plu chop at WOT/full load and see how they look. It would be safer to start with 110 and if it's rich it's less likely to hurt than if it's lean. All depends on your level of risk aversion.
Since changing jets is cheaper and quicker than changing pistons, why not start with the 110s and see how they look. If you have to come down a size, it's no biggie. You can do it without removing the carbs - which I can't do on any of our 2 smokes.
Reason that you didnt get a "install this XXX" from the SOHC guys is because they know that there is not answer
Buy 3 or 4 sets of brass and test them in the bike
WAY to many variables such as altitude, motor condition, fuel grade, time of year, exhaust brand (you sure thats not a mac)?, pods (those look small), and a million other things effect the jets needed.
Look around the SOHC site and find the Honda Carb Tuning Manual. It will go over all of the carb theory needed to understand how to properly tune the motor.
Most people that claim that they did this that or the other mod and didnt "need" to change jets dont know a good running motor from a bad one.
