white smoke from carbs?
jmeperu
my cb350 is being weird. when i turn it off sometimes it will let white vapor/mist/fog slowly roll out of my carb for cyl#2 i haven't noticed it doing it on cyl #1 yet.
i have no filters on the carbs and the motor has new pistons rings and cylinders. the motor has about 1 hour of break in time on it. it seems like it does it when the bike is off and the intake valve is open. when i slowly turn it over the mist will either come out quicker or stop coming out, depending on if it is opening or closing. and it will only do it for 2-10 seconds.
any ideas? normal? abnormal? lean?
carbs have new jets and needles. float is set correctly. float needle is freely moving.
You probably are running very lean since you don't have air filters. You can check by looking at the color of your spark plugs. I wouldn't be ridding the bike until that was checked out.
Its just fuel vapour, quite normal.
intake valve is probably open on whatever cylinder 'smokes'
Yeah the smoke is no big deal but running without air filters and not knowing if your bike is lean or rich is a bad idea.
