An amp hour is exactly what it sounds like.
a 12 ah battery will run at 1 amp draw for 12 hours.
Or 12A for 1 hour.
ah is just a measure of capacity.
The bigger the motor the bigger the battery usually because it requires more juice to run the starter.
A cb350 will crank over for a while on a 6ah battery, where a cb1100 would crank for a much shorter time before killing the battery.
If you are running the starter that will be your biggest draw. So you should stick with around stock AH to keep your starter functional for long enough to get the bike started.
To answer your question more specifically, you can go with any AH battery you want.
If you have a really good running bike that starts within a second of pushing the button you could probably get away with a 4ah, but the second you need to crank it over for longer (you forget the choke, or forget to turn the gas on, etc) youre going to kill your battery.
If you are deleting the starter you can get away with a much smaller battery.
Sonreir has a really nice writeup on all things electric that you should read through it should answer most of your questions.
