WHOA! Very Scary Problem....
That phenomena actually is called "dieseling." Two strokes are prone to it. Your fuel-air mixture starts to auto-ignite upon compression (like a diesel). It's not good for the motor, but the bike won't take off on its own. As soon as you place any load on the engine, it will cut out. In the '90s when they put the (now banned) additive MTBE in gas it was more prevalent, although any oxygenated gas blend can cause it. The oxygenated fuel increases the number of free radicals, making the combustion mixture unstable. Add in a component like a hot spot in the combustion chamber, and the mixture ignites when compressed. Pull your heads and scrape carbon from the domes with a wooden scraper and try to use gas with as little methanol as possible. When it happens, hold the brake and let out the clutch.
Damn, I never knew this was possible and I can imagine your reaction was probably something like "WHAT THE FUCK!!!????!!!????" You probably even came up with some new words when you pulled the spark leads out and it kept going lol...
Good to hear your ok though!!
