why do i always need starting fluid???
theracedude
stock 76 KZ400, runs great but first startup of every day i need a shot of starting fluid. choke is working fine but it wont fire on choke only... the smallest shot of spray and she lights right off. what causes that?
its 80 here. i think the choke is working cause when its running and i pull it out the idle goes up. i think i have good spark but maybe a hotter plug? my air fuel mixture screws were damaged and i kind of "fix" them but in the process i had to shorten them. i should have said that sooner but i just remembered that. could that be the problem? sorry but im a car guy more than a bike guy. thanks for the help...
You cant shorten the air mix screws, that will ruin them. Get new ones. Even a small scratch on those screws makes them basically worthless.
ok, i will replace those before i go any farther. thanks
