Hey All,
I got out a few times the past evening and was able to drive the bike around a little bit and while I can get it to start easily every time and idle, it only likes to idle on the left cylinder. The right one will only fire sporadically and that's when I have the idle screwed all the way in. I've played around with the A/F screw to try to get the low speed jet to start working but haven't had any luck. Additionally, I'm still having the issue where the bike likes to stall out after driving anything over 35 unless I slow down really slowly, then sometimes I can keep it running till it goes back into it's good low speed state. Having the gas cap open did not seem to make any difference and I've confirmed that the air vent in the cap itself is free and clear of debris.
The left side appears to be running just a little bit lean after looking at the plug(just a little bit white on the top of it) which I'm not surprised about since I'm driving around in 40°F, but the right side(problem side) seems to be running very rich as every time I take it out it is black, sooty, and wet. I've played around with the A/F screws on each side and didn't get much change. Is this something that can be caused by the floats being just a little bit off?
As far as the coil breaking down is concerned, I've tried to just feel the coil to see if it feels hot and it's quite cool from the outside. Is this a good way to test? It's a brand new coil.
Thanks!
