OK, got the electrical sorted. Now the idle is high (guessing 3000 rpm, no tach).
Looked over the throttle cable, look like there is slack (new single cable and new throttle on the bar).
Set timing and points.
The carb boots look good, no cracks or other places that I can see leaks.
I rebuilt the carbs last year but I recently reset the floats to 21mm and went up on size on the jet.
before I re-jetted, I didn't have this issue, but I was having problems with the RPMs dropping back down slowly after you blipped the throttle.
I am running stacks and scrambler pipes with emgo mufflers.
What else should I look for? The bike runs good, the acceleration is strong (will get up to 80mph no problem). It recently started to back fire on me through the exhaust.
I bought a HF timing gun, and it doesn't work.
thanks,
Eddie
thanks,
Eddie
