will a lithium ion battery work?
jmeperu
if i make a battery out of lithium ion cells that has the same voltage and amperage as the stock battery will it charge? i know it will run but usually you need a lithium charger to charge them.
if it wont charge i could always take apart a car charger for a digi cam and incorporate that into the battery to charge it.
typically lithium batteries require a different charge than a lead-acid or an AGM. they are cycled. first fully discharged then charged. (usually at a high amperage) I would not recommend it. lithium batteries are nothing to mess with. they can explode or burst into flames without proper care.
lithium ion batts dont need to be discharged, they will last longer if you dont fully discharge them. i work with LI batteries at work so ill ask one of the electronic engineers what they think. i think you are right about the charging, hi amps.
Not only do you need a different charge regulation profile, but Li-Ion batteries have a much lower internal resistance than lead-acid so they can self-distruct (usually with lots of heat and likely an explosion) when you ask too much of them. Basically there's no internal resistance limiting the current output. I'm not saying it can't be done or that it's not a good idea (the weight savings would be nice), but you do have to be an engineer to make it work.
