Will any forks do? Maybe a stupid question....
  • Thread starter Thread starter cory.ahlersmeyer
  • Start date Start date
C
cory.ahlersmeyer
Guest
I have a CB450 with 6" over stock extended forks.
The forks look like hell, the seals leak and you can't exactly drop the forks 8" through the triple to make a cafe racer! LOL
The forks are 35mm in diameter... does this mean that I can mount up ANY forks that are 35mm? If I find a bike that someone is parting out with decent 35mm forks I can mount them directly up and be fine?
In theory yea kinda, I'm sure someone else will chime in with a better answer. Use the search function on the forum. This question has been asked a bazillion times.
i got a stock set off a 77 cb750 there 35mm and in pretty good shape pm me if your intressed amd ill post pictures
Slow your roll buddy, you've been a member for a like 12 days.
You honestly think I didn't "try the search function" already?
Gotcha. Thanks!
Any 35mm will fit in the tree, the issue you will have are things like axle diameter and caliper and brake mounts, etc....keep those things in mind for a straight swap.
Sent from my DROID RAZR using Tapatalk 2
Will they just work? well what is working to you?
Can you fab? do you want to "make things work"?
Do you have a drum or disk front?
Im not 100% sure that the 550 will just bolt up to your wheel.
Also dropping the front end more then 1/2 inch will have a negative effect on the handling of the bike.
Honestly I don't know if you did or not. Just thought I'd give you a heads up. Don't have that many posts because I don't like wasting peoples time with the same old questions. I just use the google button and figure it out by myself.
