Will I get shot for this question??
splittie
I hope I don't get any negative reactions for asking this question here.
I recently purchased a 1981 Suzuki gs750L model and I can't stand the big double king and queen seat it has on it.
My question is, can I swap the seating for a straight 750 model seat section or go with redoing the seat pan on this one?
If pics are needed I can post some up.
Thanks
Nobody around here is going to shoot you down for wanting to get rid of the scourge of the motorcycle industry - the king and queen seat.
That being said, I have no idea myself, but am sure someone here will know or at a minimum point you in a reasonable direction.
Welcome to the site!
Thanks Tintin,
I know there are other forums that get all 'but hurt' if you talk about a non hon&@ bike.
But hey, I couldn't pass this bike up. The bike cost me $50 and the only thing that needs to be done to it is for me to personalize it and make it less ugly!
This site isn't about one or another type of bike... it's about bikes, and wrenching on them. Don't fear about your bike not being Honda. Hell, my primary bike is a Zook, and I'll probably end up with a yama twin at some point.
And Welcome
Thanks again for the info guys. I do have plans for possibly doing a rigid/chopper out of the Suzuki 750, but I want to keep it ridable while I work on the cb500 that I want to cafe. (Need to keep at least two wheels on the road)
I have a 77 GS750B that im in the process of cafenating right now. As a matter of fact...she got her engine pulled today, both the old and the new motor taken down to my basement, as well as the entire bike. I WILL have it done by spring :)
How much difference is there in the frames ?
Mine is the 750L.
What year 750L?? Pre 1980 there was no difference in frames, aside from a couple of mounting issues, if that. After 80 things got a lil more complicated but not much. There will be a difference in the frame from 77 to any other year, but its simple as well. Couple of frame bosses are different. Other than that all the 70's 750s were the same. in 80 they switched to the TSCC motor with 16valves instead of 8...personally, i like the 8 valve motors better. But i have lots of parts from an 80 750E as well...
Ahh i should read more often heheheh. Yeah you have the more modern frame design...the last change came when the GS became the Katana. but you're in the middle. Unfortunately, you're kinda screwed as far as swapping the set over. The "L" model on the post 80's had some different mounting points for both the tank and the seat, as well as shorter shocks...i think they were 12 inchers instead of 13 inchers. Your best bet here is to change the seat pan yourself. If ya have some pics, id like to see em :) I could give you a few pointers if you like. And if ya need any parts, lemme know, mechanically they are pretty much the same. And if you're feeling REALLY ambitious, i have a titled "E" model frame. Of course you'd have to find a tank and seat for it, but they are EVERYWHERE on ebay...
Another place to check out on the web for your GS is www.thegsresources.com
A word of warning tho...there are divided sects on that site...the purists and then the tinkerers...Most of the purists HATE HATE HATE people modifying these bikes...and you may catch a bit of flack over there...just ignore them :P However there is a good amount of people that mod thier GSes...some even get crazy and swap front ends to Gixxer front ends and swingers, with monoshocks...etc.
But if ya need any help at all, gimmie a shout :)
Thanks for the info 'Soldier, I have thought about doin' a chopper/bobber number on this bike with a rigid tail end then it wouldn't really mater what seat arrangement I have cuz it will be all custom.
I talked to one of the guys that builds the rigid Yamaha XS650 tailends and he told me that he could do it for me (make a kit) if I got him some pics and measurements.
I am sure I would have to get a different tank, since this one is so WIDE.
I will keep in touch and get some pics posted this weekend.
Hrmm Keep in mind, you can use bar stock for some ridgid spring replacements, BUT these bikes werent designed to be ridgid frame, so be carefull. I'd hate to see your frame crack and you go tumbling down the road. I had some ridgid springs on my bike when i first bought it however, and it didnt seem to flinch in the back, so you should be ok. If you decide to get rid of that tank, let me know, i'd probably be interested in it!!
I am actually thinking of doing a complete rear swap, including replacing the swingarm and putting a springer type solo seat.
Are you talking about just replacing the springs with solid metal rod? (I think thats what you mean)
Yeah that's what i was speaking of. Again, im not sure how the kit you're talking about works, just keep in mind, a solid, or ridgid swingarm set up will put alot of stress on your frame at the mounting point. It *shouldnt* be a huge factor, depending on your build and weight, but the frame structure wasnt designed for such stresses. Alot of guys who do a ridgid conversion will add some extra frame support in the rear. Just some things to keep in mind. I'll be interested to see what you're doing so do keep me informed :) I love these Zooks, and the motors are damn near bulletproof. The 8valve models use roller bearing cranks, which are near impossible to fuck up. Unfortunately the TSCC 16valve (which yours would be) design switched to a plain bearing set up. They are still VERY durrable however. Have you checked your valve clearances yet? Also if ya need any info, i have lots of it, and i have a manual that includeds the TSCC design, so if ya have any questions, feel free to ask :)
The style I WAS thinking about is similar to the style used on the Yamaha xs650.
I saw a rigid rear on ebay also (Prewelded too) but the framework of the Suzuki looks to be a bit different under the tank area so I think I may just try more of a cafe style and try to get rid of the seat section and pound some spots for my knees to fit into that tank :o
By the way, here is the bike.
Man that thing is in really good shape! Pounding the tank on these is cake...i did it on one of my tanks...got some pics up of it in the tank and seat section, and it turned out pretty darn good if i do say so myself. Still dont have it painted, as im sending all of the body work off to get it done, but the fill work is done on it. I used a pattern i traced onto some paper, and transfered on to the tank based on where my knees were when sitting on it, and then once i had the pattern on the tank, i used a pretty heavy ball peen hammer, and started about 3/4 inch or 1/2 inch in from the line on the tank. Using small solid taps, i moved in a line, and didnt get the tank pounded in anywhere deeper than another spot. It pretty much does what you want it to once you get it going, and the only tricky spots are where you come across the body of the tank cos it wants to cave pretty easy. Also, pay attention to YOUR pattern, as the tank badge mounts arent lined up the same from side to side, so that can throw you off just a little bit. But all in all i think i spent 20 minutes a side pounding. Pretty easy. Was my first attempt as well.
Do you have rearsets on your bike?
I am 6'3" and not sure if I am going to be comfortable using the stock locations.
Also do you have pics of your bike(s) posted up? If so, what section(s)
Well, i was considering rearsets, and acutally picked up a set via trade. A set of Raasks that would bolt right up to your frame, but unfortunately, not to my 77's :(
I too am almost 6'4 and i find the stock pegs actually quite comfy. I tried the rearsets on the 80 frame i have, and i dont think i would find them as comfortable as i had hoped. Lil bit of hip crampage there. So i am debating on what to do with these.
Yeah i have some in progress pics, in the Big Arse Projects, "Finally...Pics of my GS750 Cafe Project" or something like that. its the only GS cafe project still goin i think...
Keep in mind, this is an ongoing project, so she surely isnt in pretty shape...lol...she'll be purty by spring tho :)
There are also some pics of the tank i have been working on in the tanks and seats section "Tried my hand at pounding a tank" I think.
Thanks for the info
I'll check out your bike.
I finally posted some pics of my bikes in the Intro section 'Chiming in from Cen Cal'
Talk at you later
No prob man! Lemme know if you might be interested in these rearsets. I dont think i'll end up using them.
You got any pics of them mounted on your bike?
Also, saw your post w/ pics of your bike, looks nice.
I will probably go with some of the same stuff as you have on yours (i.e. clubmans/bobbed tail/smaller seat/atc)
By the way, are you using the airbox or are you gonna use pods?
Oh yeah, how much are you wanting for the rearsets?
