Will My Fiberglass Cafe Seat Hold Up?
kzcafe82
I have previously mounted my fiberglass seat on my Kz550. I have it mounted up on 4 posts consisting of about 1 inch of a spacer and two cross supports going side to side as shown in the picture. It is all held together by bolts with washers going down through the seat, through the cross support, through the spacer, and then through the frame held on by a nut. The seat I have is the interceptor from Roccity. It seems to be of high quality but I want to be sure that it will hold my weight (185lbs) without any further support. The photos should be a decent visual representation of my mounting technique. I dont want it to crack, splinter or anything else like that. I am open to comments and suggestions. Thanks!
can you take a picture of under the seat, specifically the mount to the frame and the underside where you mounted the turn signals and the license plate mount
what material are the 1" washers? and the cross supports-they flat or round? pic of that support you made would help.
to session101, i will try to remember to take the pic for you the next time im down in the garage. As for the tail light i mounted it directly to the seat using a regular drill bit on the outer holes and a step bit to the correct size for where the wires come out of the light(as shown in the pic i have attached). As for the turn signals, I mounted my mini catseye rear turn signals it the location of the original turn signals. I just simply had to drill the holes to a size or two bigger. Feel free to ask any other questions. I am more than glad to help in any way possible. If my description isnt clear as to how i did it let me know and ill try to explain it better. Hopefully this will help.
to midnightcafe, the washers you see in the picture are just your typical metal washer. The metal i used for the supports are flat stock 3/8''ths thick by 3/4'' wide. I will also try to get a pic of my mounts too because they see to be effective. With respect to the supports i have now, i feel that the strength side to side along the supports is plenty strong, im just curious as to if it will hold up front to back. I think it will, its just that i dont have and support running front to back. The supports are only like 10 inches apart though so I think there is enough strenth in the fiberglass to support my weight but i want some others opinions because maybe my thoughts arent exactly accurate and i might need to reconsider adding to what i have already.
I would not drill holes thru the frame like that, lot of stress in that area and tubes are not that big to start with. Much better to make clamps that bolt on .
I see what you are saying. But I will eventually post a picture so you guys can see what i did. Up front i did drill either 1/4 or 3/8 holes through the frame rails but i dont see vertical holes as an issue. If the were horizontal I would reconsider. Also with the bolts down through the frame I think It will definitely hold up. As for the back mounts, those holes actually go through a cross support behind the battery and up above the rear wheel. I dont think that it holds that much weight. My biggest concern is the fiberglass. I havent dealt with it that much so i am somewhat unfamiliar. Thanks for the advice. Hope to see some more and get some new ideas tossed around.
I have just made a steel seat which originally had 4 mount points. The steel is 1.5mm and I found a small amount of flex in between the mounting points.
The end result was to weld another support in between and it's totally eliminated the flex.
Not sure if this is analogous to your situation as I am not sure if resin is less/more flexy than steel, but thought I would share my experience.
I may have gone overboard but I didn't want any paint to crack on thr seat when it's done.
Here's my mounts (silver bits are bolt holes) which clearly shows the 3 braces, next photo is with seat:
Good job, and good thinking. I like you mounting technique. The reason I did not do something like that is because they are not removable so maintenance would become difficult. I wanted something that could be disassembled. Also, if motorcycle frames are anything like automobile frames, if too much stress is put on a horizontal weld, the weld can break away from the frame and create a crack. Now I highly doubt that a bike frame would be under that kind of stress, but isn't maintenance in that area tough to do? If not, that is definitely a good way of going about mounting a seat. Thanks for the photos.
Yeah maintenance would be tough, but the only serviceable part is the seat threads and they can be replaced from above. I was going to weld nuts on before so this rivet style bits are much better as they can be drilled out and replaced if they get damaged.
I havent relocated my battery and I do not have intentions to as of now so that would be difficult to maintenance as well. I also think my way will be effective because the spacers are actually hard rubber which will reduce vibration. The reason I needed a spacer is so that I could clear the battery box. It is suspended within the frame on mounts that exceed the height of the frame rails. I really like my mounts because they clear the battery, reduce vibration, and hold my seat stationary. I will also be putting on an upholstered seat pan/pad which will help distribute the weight on the fiberglass seat. I dont think it will break/crack/splinter but I was wondering if anyone had experienced this situation.
Not yet but a few people have asked for pics so ill try to get some pics one of these days and ill post them. What I ended up doing was putting hard rubber spacers between the frame and the seat which gave me enough clearance over the battery box. it doesnt actually touch the box.
I figured that was the case as it was stated so earlier in the post. I was just curious as to how the seat looks with the original kawasaki rails forming not parallel lines with the seat, or if the seat was deep enough to hide the frame rails.
Oh ok I see what you are saying. Check out my build thread. You can find it on my profile under my posts. I have quite a few pics posted. The seat is deep enough to cover the rails but even if it wasnt it would still follow the lines of the frame. It is relatively straight. Check out the pics and let me know what you think.
