the number and size of the strands does nothing to effect the ampacity of the wire; it only effects the flexibility of the wire. wire is rated by gauge look up 'ampacity table' on google it will tell you how much current a wire of a given gauge can carry safely. from an electrical stand point bigger is always better, but the bigger you go it will cost more, look worse and be harder to wire. go any smaller then stock and shit will start to melt or start a fire. the phisical size of a cable is not a good indicator of it's gauge as the insulation thickness and type of wire can effect the outer size a lot. all wire should the gauge written on the outside of the insulation use that and the table and you can't go wrong.
