wire
funkja
Active Member
just got my spare harness shipped not a bad $10 find considering its still in very good shape! but anywho i'm re-wiring a few sections and am wondering whats a good place to get quality wire in all the stock colors?
Don't know about stock colors - for that you'd likely be best just scavenging out of old harnesses.
That being said, I did my new harness from scratch and used marine wire for the lot. Made by Anchor Wire.
Comes in a bunch of different colors, is very high quality, individual strands are tinned for protection and flexibility etc. I'm overdoing it, but it is nice wire. I think I used 16ga for it all.
"NCOR Marine Grade™ wire is manufactured from tinned copper stranding for maximum protection against corrosion and electrolysis. Ultra flexible (Type 3) stranding resists fatigue due to vibration and flexing."
perfect! called around and there's a boat dealer 3 miles from my house that sells the ancor primary wire in 20ft rolls @16ga. type3 for $7.49 each. 12 diff colors. headin out there this weekend. awesome thanks tim!
Damn Tim, that's some good looking wiring!!! How much coin did it set you back to get all the supplies needed for a full harness? I'd like to do something like that if it's not too cost prohibitive.
I've tried not to keep track of costs ;)
I ordered my braided sleeving from www.cabletiesandmore.ca and picked up my heatshrink at Sayal locally. The bullet connectors etc. were bought from Z1 Enterprises.
I've been a bit obsessive in my wiring, as you can see, sleeving even individual wires as they exit the larger harness and then using little bits of heat shrink to color code it. I did use different color wires as well, but you can't really see the colors through the sleeving.
I spliced new wired into my switch pod unit as well:
And extended / sleeved the brake light switch. Also did the headlight lamp socket etc. etc. etc.
I also used the sleeving and heat shrink to make my grey speedo cable black. Not sure if I'll leave it like this and do all the other cables or not.
