wires comming from alternator
gamaken
Hello there,
I m pretty new on bikes and forum, i just bought my first bike a 73 cb 350 its a really
reliable and fun to drive bike,
Im in the process of fine tune all the small details and
right now im replacing the switches on the handle bars, knowing this my question is about
2 wires that according to the schematics are coming from the alternator
the switch im working on is for the headlights, its not the oem but its the same kind with the slide lever off low and high everything is pretty much straight forward till the point that this switch don't carry space for this
2 wires to hook on , what can i do with this wires should i just hook them together ? what are this for?
will affect the charging system?
thanks in advance for your help and time
if you mean the yellow and yellow/white, you can connect them and run as full yellow. Honda thought is was a good idea to splice the current over 2 wires. 1 wire is always hot, and the other one helps when you engage the headlight (thru the switch). By connecting them period, you have some extra punch to keep the battery up and such. Done it a lot, no biggie.
So then can i just joint both wires and leave them out of the switch,
cause like i said i dont have place to put it on the switch
thanks for your prompt answer
Yes.
Splice the white wire coming from the alternator into the yellow wire from the alternator and you can eliminate the entire yellow/white wiring run.
yup, and no problem ;)
