Alright I extended the wire from the ignition to the starter solenoid. No big issue. Jerry rigged the battery wires back to the starter and viola, I have power to the starter.
The electrics and the conectors on this bike are in poor shape. I will need to replace many a connection after i get all this stuff moved.
Any tips on getting the ounting bolts for the ignition, starter solenoid, and R&R to relase or free up? I have no impact driver and am getting madder by the min..LOL
Does the solenoid ground through the metal mounting frame? or just through the mounting ground wire? It is the origional starter I believe and has seen batter days. I want to use it temporarily. The recessed plate i had designed uses a hard cutting board (plastic) and p clamps to recess it between the frame rails. If it needs to gground through the mounting I need to start over now.
