Wires to starter
gk45011
Coast to Coast
Trying to relocate the electrics up under what will be the seating area on a GS450. Only wire that seems rediculously to short is from the starter to the starter solenoid. Any ideas on how to extend this? anything i should know or be worried about?
Gary
I had the same problem when I built an electrical chassis for my GS450 to tuck the electrical stuff up under the seat.
I made a new cable from solenoid to starter using 8 gauge audio power wire and crimp-on terminals. I backed up the crimp by soldering, also.
I found it with a supplier on Amazon. It's usually available in clear, black, red, and blue. I bought the red and learned that the color fades with sun exposure.
Here is a sample supplier:
http://www.sonicelectronix.com/cat_i239_8-gauge-power-ground-wire.html
The terminals I got at Lowes or Home Depot in the electrical department.
Thanks Alpha,
So I will have to extend it. On the starter end do I just open the starter housing? Is it a direct bolt on replacement?
Gary
Remove the two screws that hold on the starter cover, and you will see how the wire is connected to the starter.
Alright I extended the wire from the ignition to the starter solenoid. No big issue. Jerry rigged the battery wires back to the starter and viola, I have power to the starter.
The electrics and the conectors on this bike are in poor shape. I will need to replace many a connection after i get all this stuff moved.
Any tips on getting the ounting bolts for the ignition, starter solenoid, and R&R to relase or free up? I have no impact driver and am getting madder by the min..LOL
Does the solenoid ground through the metal mounting frame? or just through the mounting ground wire? It is the origional starter I believe and has seen batter days. I want to use it temporarily. The recessed plate i had designed uses a hard cutting board (plastic) and p clamps to recess it between the frame rails. If it needs to gground through the mounting I need to start over now.
Yeah its in the works. I have a feeling I'll be using it quite a bit till i get all the old phillips out.
Gary
