wiring issue
cardiablo
Hey there guys,
I'm doing the wiring for my cb350g cafe and I'm having problems getting everything right. Before I tore down the bike everything was working electrically. Right now I'm connecting the harness to everything except for the lights. i really want to hear the motor stars so im trying to connect the starter motor. i have connected everything to where it should go on the harness. ive connected the guages and the neutral light lights up. the ignition flasher and horn aswell as the regulator rectifier. and anything else it needs to run. i want to start it but i cant get the starter motor to turn. nothing happens when i press the button. also nothing happens when i try to use the horn button. i dont think its the starter solenoid. It may be a grounding issue (im not sure how many ground ponts there has to be) but I don't know where to look to next. Any input would be greatly appreciated whether it be solutions or where to check
Almost definitely a grounding issue. The horn and the solenoid both get grounded against the handle bars in order to be activated.
Bust out your multimeter and make sure you have good continuity between the bars and the negative terminal of the battery. Less than one Ohm would be good.
Thanks that was exactly the case. The handlebar risers have rubber bushings and they weren't grounded. I put a ground wire on the bolt to the frame and it's all good now
