wiring issues with '72 R5 build. Help??!!
diesel450
"Fast with a past"
DTT BOTM WINNER
Okay, little problem here and I am no whiz with wire so I'm putting it out there for you guys and gals.
I got the wiring pretty much back together and had no trouble getting power thru the system, headlight works etc. what I noticed is that when the ignition switch is on the coils get hot. Me thinks this is bad and that I probably have something wired backwards Here is the diagram www.lawrenceotoole.com/.../R5wiringdiag.jpg
Its confusing because the wire colors change as they hit the coils, one is orange, one is gray. I get the basics but have no confidence just moving shit around. any thoughts??
I did recheck to be sure that the coils are secure and the battery is grounded properly.
Any thoughts?
Okay, that helps, that makes sense to me. by the by coils don't get hot when ignition is off. I had a thought. the kill switch was toast on this bike and I bought a universal but haven't installed it yet. I thought maybe not having that in the system was part of it. I "hotwired" those wires together but it made no difference.
using the multi meter I have no volts at the points.
This is so frustrating there are only, like 12 wires in the whole system and I can't get it. I feel like Im back in 11th grade Algebra. I just never saw a need to know what X was.
Any chance you can walk me through a step by step diagnosis?
not sure why link isn't working try www.lawrenceotoole.com then look for the wiring diagram link.
Okay, so I have that correct. Should I have power at the point connecters with the ignition on? I do not at this point and I am pretty sure that I did when I first powered it up. Points and condensers are new. If I understand this correctly the spark from the points goes to the coils and is magnified before being sent out to the plugs so maybe I'm not supposed to have a read at the points until the bike is cranked? Or is it an "open" system where the 12 volts from the battery is going through the hole system when the ignition is on?
PJ, I appreciate your time and thought on this.
Oh, the other minor issue is I have a couple wires in the head lamp bucket with no place to go. Looks like the diagram says that the dark green wire and the dark brown wire are wired in to the brown wire here. no other place for them to go.
I'm still waiting for the tail light and turn signals to arrive. think I'll have better sense of what is left once I can get those into the system.
Just had to chime in - with the ignition switch in the "on" position, if the points are touching the coils will beging to warm up. But if the points are not touching, then the coils will not warm up. And the points are just finishing the circuit to tell the plugs when to spark. I know - WAY over simplified for some people.
And as PJ said, if you open the points manually, you should get spark. But the ignition has to be "on".
Dude, you cannot over simplify this for me. I really know very little about how electricity works. I do have a pretty good logical mind though and I know I can pick it up. I just have never worked with this stuff before.
First, let me say that a couple months ago I didn't know squat about how an ignition actually worked. So I didn't mean over-simplified for YOU. I had a problem with my ignition when I got my Honda. I researched it all online the best I could and got a little confused by the terminology and stuff. Once a friend of mine explained it (basically gave me the Ignition for Dummies speech) it all clicked for me.
Anyways, having any luck?
No offense taken. My uncle is an electrical engineer and he is always giving me shit about being a person of reasonable intelligence but not being able to follow a wiring diagram. Its starting to click though.
No time to work on it. I'll get back at it this weekend. I have a suspicion that I have grounded out the points. I know I didn't pay to much attention to the fiber seperators when I reassembled them. This would probably explain why I had some power reading at the points at first and not since. I'll keep you all posted.
PJ, read up on ignition and I think I am understanding it correctly, I probably didn't explain it very well. What I've read is that the coil is sent a low volt spark from the point and makes it a high voltage spark before sending to the plugs. I'm sure there is more to it but in a basic sense that is what is happening, right?
Oh, yeah, I read about how to check the primary and secondary voltages etc. while testing the coild to determine where the problems are. I don't believe the problems are with my coils, yet. well at least not these problems. :P
Alright guys, progress! PJ you nailed it. I had the two leads at the points actually together. I redid the connectiosn with one on each side of the insulator washer and presto! Spark. I've got good spark at the points on the right side and weak spark at the points on the left. I also have spark at the plug on the right side I couldn't see spark on the left plug. I'm going to double check all the connections and point gaps and try again but thought I'd post this to see what other ideas you all might have. I am difinitely replacing the coils though at this point.
Thanks for taking the time to think about this fellas!
