Wiring novice! need some help
Sorry for my wiring ignorance, I am re-wiring my royal enfield bullet 500 and have drawn up a new wiring diagram. I am unsure how it will go so i would like some of you professionals to look over it and let me know where/if i am going wrong and how to fix it! any help/comments/reccomendations will be greatly appreciated.
Thank you!
I think the polarity on your component marked "ammeter" may be reversed.
10 and 14 are connected when the switch is "on?" what about 6 and 2? We need to know what connections are made in the switch on top.
Your tail light will never come on because it has no path to ground.
The rectifier/regulator relationship is strange... is it one unit that does both?
-Deek
thanks for your help deek,
i have added a ground component for the tail light, and as far as the ignition switch for IGN 10+14 and 6+2+4 are connected and for the lighting and all else i believe 12+8 and 16+2+4 are connected.
and the regulator and rectifier are two seperate units, all the wiring from that is copied straight from the original wiring diagram so as far as i am aware it should work, but that is all beyond me!
hope this helps
Ammeter usually needs to sit between battery and the rest of the circuit or you're only measuring part of your current.
