wiring question and tires
kevshin21
I am trying to remove the battery compartment to the back to have that cafe look. (here is the important question) How (or what) can I do this to achieve that look? Can I extend the battery wires by soldering new wire? Also the previous owner put a 100/90 x 18 in the front but the haynes manual said it was designed for 90/90. If i install a 100/90 will it have any ill effects such as head shaking etc? Thanks for your help.
what bike?
what is stamped on rim (WM0, WM1, WM2, 1.60x18, 1.85x18, etc)
If its a 1.85 you'll be OK but it is really too wide, if its a 1.6 or narrower, take it off.
you can use it but it will never really be safe if rim mis too narrow (lots of people here use waaaayyyy oversize tyres but they don't ride hard, ::))
If its universal it may fit on rear?
You can extend main live to solenoid, safer to get a longer cable rather than extend whats already on bike though or make a new one (stereo power feed cables will probably be about same gauge?)
PJ
It is an xs400 I believe it says 90/90 x 18 and how would I extend the main live solenoid? wouldn't getting a longer cable basically mean having to solder anyways? Forgive my ignorance, this is my very first mechanical project.
Your battery cables will have large crimp connectors on each end to connect from the battery to solenoid (+ve) and battery to frame (-ve). If you get longer cables you'll need to get new crimp connectors as well to make the ends. Sometimes they are soldered as well as crimped, but you can get away with just crimping them (as long as you crimp them tight).
The rims a 3.00 x 18. A 90/90 is a perfect fit. A 100/90 is slightly oversized, but should work fine, as long as your not going knee down into corners.
http://www.webbikeworld.com/Motorcycle-tires/tire-data.htm
The reason for not soldering your main lines that go to your battery, or extending them is very simple. You're adding a potential failure point. Shoddy solder joints fail, weak crimps fail, sparks fly and hilarity ensues, considering where these wires will be running, and where you the family jewels will be when they fail.
When it comes to this one thing, get the right length lead. Some electrical suppliers might crimp the end on for free, with their correct set of crimping tools. They're cool that way, sometimes. Also, keep in mind that the wire has an oil resistant jacket, so keep that in mind when choosing wire also.
loudest143
loudest143
Just to clarify, I wasn't suggesting joining 2 leads together to extend the battery leads, I was saying that the crimp connectors are sometimes soldered onto the wires (as well as being crimped). Soldering 2 leads together to extend the lead would be hazardous as you've said.
Another option with the -ve lead would be to ground it in a different spot on the frame that is closer to the re-located battery. This way you'd only need to make a longer +ve lead.
The rim on XS400 is NOT 3.00" although the tyre may be.
The front is either 1.60" or 1.85" (I think WM1, 1.60"?)
You have to look on the rim not tyre, either on spoke (with cast wheels) or stamped into rim (with spoked wheels)
If its a custom, the rear is WM4, 2.50" and will fit a 130 or 5.00x16 tyre even though a 120/90 is stock (I have one on back of my XS800 so know for a fact that's the size)
PJ
I hope someone can help me with this wiring nightmare. When I was removing the front end off of the bike I marked and labeled everything with numbers on bright green tape as you can see in the pictures. I ended up missing one since it was getting dark (few days before not in the pic) and when I try to figure out what goes where I cannot find the missing link. I have dotted it yellow, so where does this go? I believe this is for the headlight/blinkers. How can I organize this mess?
What colour is the lead? If it's black, it's probably the earth for the headlight connector (which is probably connected to another ground). Should be OK to leave it if it's just an earth.
As for the nest of wires - get yourself a BIG headlight bucket ;)
PJ
Sorry, I misspoke there... The TIRE is a 3.00 x 18. At least thats what the factory specs are. Sorry PJ, I know your a stickler for tire/rim size specs.... ;)
Thanks guys I just bought some kenda challengers 657 and I am still contemplating if I can tape the black ground to the bucket.
What are the other wires next to it for? Like Hillsy said, it probably is a ground for something.
If its a ground, you cant tape it to anything, especially plastic. Gotta find out where that goes. It comes out of the switch housing right? Well, use the process of elimination. You know what the other wires do and where they go right?
