rappz7
So Ive gotten to the electrical on the build and i have a question. The harness is pretty much custom now and far from stock besides the charging system. The power for the headlight, gauges, and dummy lights (built into the new speedometer gauge) are no longer drawing power through the mess of wires that use to be the stock clutch loom but instead drawing power from a single hot wire ran from the regulator/rectifier. My question is this, can I run the power for the dummy lights, and gauge back lights to the same power as the headlight using a single 10amp inline fuse? I did away with the stock fuse box that use to be located in the middle of the handlebars. I figured I can fuse them all with a high enough rated fuse since there no longer individual circuits. Also i should add that the back lights for the gauges as well as the headlight will be wired to a switch that will turn them all on at once when needed. Also can i tap into my backbone wire to hook up my new horn or does it need its own power with a fuse? I have a 1979 cb650. Thanks and as always your input is appreciated.
