Wiring Removal
iSack1L
Whats the proper way for removing the wiring without damaging it? Do most people cut wires, etc.? Mine is kind of wired through parts of the frame and I don't see how stuff will fit without major disassembly or ripping into the wires.
The harness is designed to go through spaces within the frame. All the connectors slide through, you just need to figure out which way. It's always better to keep the harness intact as possible.
I figured that. The only thing I was confused on was removing the wiring from the lights. One of the wires is easily removable, but the second, which I assumed was saudered to the bulb socket (i could be wrong b/c i havent tried), seemed harder to remove. Thoughts?
Do you mean the headlight socket? Usually there is a bullet connector on each wire, but as with most old bikes anything is possible. You can always snip the wire and re -solder and shrink wrap it later. But, Lord yes, keep as much together as you can, life will be so much easier later.
Terry
J'ville, Fl.
