Possibly. On the same line ... I'd think you'd need a pair of specific Benelli forks for this hub ... I mean .. how many pairs of forks have you seen that are ready for dual front drum brakes like these?
There only thing you need is a brake stay mount somewhere. I got fancy and had a tab welded to my forks to match the brake hub. Most front drum brake hubs just use a simple bracket which can easily mount to the fender mounts of any forks.
This particular hub looks like it has a nice beefy nut forward of the axle, to which you'd bolt a bracket that runs up to your fender mounts. I'd make one that bolted to both fender mounts that are typical on most forks for added strength/security.
Check the front wheel of this bad boy - nice read too.
