Wtb: cb350 carb slide
SONICJK
Reminds me of...me No, I'm sure of it. I hate him
I am looking for a carb slide out of a cb350.
Mine is a 68, so it may or may not be the same as the newer versions.
My slide is dented and doesnt operate smoothly on the right carb.
Cheers,
Justin
How fast do you need it? I'm in PA for a couple more weeks but I know i've got a couple extras sitting on the bench at home.
I mean the one I have now "works" somewhat and the bike is still in pieces at the moment hah so that would be awesome if you would let one go.
Not a problem, pm your address and once I get home I'll put one in the mail for the cost of postage.
By the way I know what you mean by being in pieces 8) I'm in process of doing some motor upgrades and making a other bits. As it sits right now:
-1969 CB350 frame de-tabbed, welded and tappered steering bearings
-Stock tank, +0.75mm pistons, hi-comp valve springs and radical cam
-Re-worked headlight bucket and modified stock control housings
-1998 R1 Forks and Tokico blue spot brake calipers F/R
-2005 ZX636 Clip-ons and brake master cylinder
-2008 CBR1000 Rearsets
-1994 CBR600F2 wheels front and rear
In progress;
- custom seat, possibly incorporate inverted SV1000 taillight with integrated signals
- Figure out rear wheel chain alignment
- Mikuni VMs or Keihin PWKs or FCRs
- Pamtec cb350 ignition
- LiPo or similar small battery
- starter delete plug
- possible custom single sided swinger similar to the Ducati MH900 using VFR400 or NSR250 components
- KA performance tensioner and Tsubaki cam chain
http://i1170.photobucket.com/albums/r526/1969honda/IMG_8687.jpg
http://i1170.photobucket.com/albums/r526/1969honda/IMG_8686.jpg
http://i1170.photobucket.com/albums/r526/1969honda/IMG_8685.jpg
http://i1170.photobucket.com/albums/r526/1969honda/IMG_8684.jpg
(My headlight mount wasn't completed in these pics, just laying out the material dimensions and checking hole spacing at the time.)
I'm damn jealous of those forks!
Looking good.
Mine Is 100%ton down at the moment. Just got the frame back from powder and started rebuilding the engine.
Ebay for $100 with triples, pressed out the cb350 stem and then pressed it into the lower of the R1 triples. I sourced all of my own bearings from several online retailers before finding out about the all-balls conversion tables. they both shared a 30mm lower stem. I think most of your gsxr's have the same lower bearing. I got the idea about 4 years ago from pictures of a bike on the www.ohiocaferacers.com website, I've just been busy ever since and never got the bike fully assembled since then.
