Chuck78
WTB GS425 project, or 425 engine, or 425 cylinders & GS400 engine/bike, GS400X
I'm looking for an affordable Suzuki GS425 project bike to build next year with a good frame and rebuildable engine. I'd prefer the standard GS425N model and wire spoke wheels, but the GS425E model would do as well. I would consider an GS425L model frame, but I am not sure what the differences are between the frames.
I'm wanting to build a big bore version of one of these bikes with much larger sleeves, and I am "hoping" that the GS425 cylinder block can accept larger sleeves bored into it than the GS400. I could go up to 70mm 462cc on a stock 425 cylinder before needing to re-sleeve, so that is a big plus. With re-sleeving to much larger sleeves, I believe I could go up to 530cc+ on the GS425 cylinders. The larger cc's will require larger valves and a head porting job, but the extra investment will be quite worthwhile and make this a very unique GS twin.
It has a later GS450 engine (I'd need to trade that one out for a 400/425), but there is an incomplete project bike 1977 GS400X locally that could be had for the right money (was $500, current owner said I could make an offer) that already has wider gold anodised DID rims laced up into GS hubs with a GS1100E swingarm, and I am dead set on going with the longer stroke roller bearing bottom end of the first gen bikes to get the kickstart primarily, as I want to strip down this bike as much as possible to shed weight, add GS550 single disc forks or GS500 forks and GS850 triples, 310mm Honda CBR900RR rotor, GS500/Ninja twinpot caliper, lighter/better rear shocks, custom 2:1 exhaust, etc so that I can take a 372lb stock bike down to around 330 lbs for better handling and power to weight ratio, and on top of that, building a modified engine to make this substantially lighter bike accelerate at least the same as a pods and pipe and rejetted GS550 ("fast enough" by my standards).
With the Appalachian Foothills starting just 35 minutes southeast of my house here in flat central Ohio, with twisties galore out my back door basically, and West Virginia and Kentucky a 2.5 hour ride away, I really am wanting to experiment with building the lightest possible GS that I can to make a very flickable ultralight corner carving machine. I'm pretty happy with having shed my 520lb GS750 (was 532 stock wet weight) down to about 485lbs, as this gave me huge handling/cornering gains and that bike rides awesome now, but I'm really dead set on this first gen kickstart GS twin to satisfy my tinkering desires and give me a permanent second bike aside from my wife's and a spare that I am building for a friend.
Not in a huge hurry to pick up, won't be starting this until well into next year after major house renovation and moving, but any leads possible are much much appreciated.
Thanks!
Thanks!
