X5 Megacycle install HELP! Please.
legendary_rider
Jump in with both feet.
I went to install the X5 cam from megacycle in my cb350 today and the part that bolts onto the sprocket won't squeeze through the cam case opening. It's a tiny bit too small. Not sure but can I grind out a touch to get it too fit or will that cause a leak somehow? Can't see why it would. Or am I missing something altogether. Searched google and nothing. Searched the forum and nothing. I feel like a complete retard cause no one else seems to have had issues with it.
Could someone please help me out? Probably someone into racing? Thanks.
Hi Sonrier. Nice to hear from you again. Thanks for your reply.
Well I just got some pics in from Buff Harsh at THR. Apparently I do have to remove a lot of material from the housing to get the X5 to fit. Here are the pics he sent me in case anyone else searching this forum has any "problems and need help installing the X5 camshaft from megacycle in the cb 350".
It was pretty funny. In my desperation I was even trying to watch that time elapsed build they did on youtube to see if I could make out if they had removed material or not. lol
If you're talking about the holes in the side, you should be OK grinding out enough room to slip the camshaft in. The side covers go on there, anyway.
For the inside journals you mentioned, I would leave that to a machinist. They will likely need to be very precise to avoid abnormal wear. That is, if they need to have metal removed at all.
Grrraawwww! >:( I ground out all the spots on the cam housing then the sprocket wouldn't fit due to the size of the lobes on the X5. I contacted THR and they say that the stock sprocket can be ground out to fit or they have custom ones for sale to fit. So I grind out the stock one. Fist lob fit, then the second one wouldn't. So I grind out for the second one to fit. Then the damn X5 won't sit flat against the sprocket cause theres a lip on it. Gonna have to break down and buy the "custom sprocket". Wish they would have mentioned that when I bought the camshaft. What a pain in the ass. Won't be doing this crap again on the other 10 bikes I have to rebuild.
"Megacycle X5" should be renamed "Megapainintheass 4U".
Crap - how much extra lift are you getting with this cam? Do you have the clearance with your stem guides and seals?
Not sure. I've got all the specs at home. Racers put them in all the time though. You need to use the racing pistons too though according to megacycle. They're just 67.5 Wiseco's. I also put in lightened 5.5 mm valves. I'm going to do a build page I think.
I had the motor almost all together and decided to tear it all down again and start over. I powder coated the motor and wasn't really happy with the results. I'll start fresh and take lots of pics.
Anyway THR is sending me a new sprocket the is adjustable and I can "degree in" the cam? I don't know how to do that so I guess I'll leave that to a shop.
X5 cam - this is a full on race bike, yes? That's pretty lumpy for the street. Extra lift and duration mean that the motor lacks compression and low end drive and pockets for valves need to be much deeper.
Degreeing that cam requires a good large metal timing wheel and dial indicator. Assemble the motor using a mid point on the cam slots and set tappets to megacyle clearances and then slowly rotate the crank 5 degrees at a time and measure lift on one valve. Repeat for the matching exhaust valve and the other side.
With all that data, determine the degrees before or after TDC/BDC that the valves are lifted .040" ( or whatever figure that megacycle say for checking). Then determine how far advanced or retarded the cam is on all 4 lobes. Reground cams are always a compromise and are rarely accurate, so you have to decide what compromise you are prepared to live with. Just remember that advanced timing adds low end power and retarded tilts the power curve to hurt bottom end and help the top end by shifting peak toque.
It's not hard but it takes time to get it right. It's easier with a cam doctor or similar linear digital transducer and software, but they are costly.
No regular shop I know of can get close on cam timing and many race shops are also a bit sketchy.
No worries. Swapmeet - I figured that the point you were making was that it isn't rocket science. I needed a break from work, so spent a few minutes to provide the long version.
Before degreeing the cam, make sure you verify TDC by using a positive stop. TDC isn't always where the marks on the rotor/stator says it is.
Thanks guys. Seems over my head at this point for me though. I'm gonna go to a performance shop and see if I can pay them a little extra to show me how to do it. At this point with so much cash into it I do not want to do something stupid.
It's a lot easier to do that you'd think. Give it a try first and if it's not working out, then you can fork over the $$$. Hit us up if you need specific details; that's why we have these forums. :)
I'd start by reading as many articles on line as you can stand. They will mainly be Auto related, but the principles are the same.
Looks like you have one of the heads that needed modifying for stock cam, probably need a lot of cutting to get high lift cam in?
As already mentioned, degreeing cams isn't difficult, just time consuming
